NEEDED REAL BAD - Toyota IFS wheel hub
  • Thread starter Cummins Land-Rover
  • Start date
C
Cummins Land-Rover
Had an "incident" on the trail this weekend - I need a wheel hub from an IFS 4x4 minitruck or 4runner. I am on three wheels and going nowhere until I get parts. Anyone with something laying around please PM me, ideally I need something ASAP... Thanks..
C
Cummins Land-Rover
I got it fixed last week but now the other side just blew up! If anyone has a hub I would really appreciate it. Just to clarify I need the cast iron hub that holds the spindle bearings, the part which the rotor and the wheel bolts to, from an IFS 4x4 Toyota. Anyone with an IFS parts truck?
C
CAVEMAN
I should be able to find you one J.L. - it is just a matter of getting it to you .
Other than breaking both hubs so far , How do you like the conversion ? Would you go that route again or just go with wheel spacers instead ?
C
Cummins Land-Rover
I got a pair off of bancm (Chris) last night, I should have it back together tonight.
It's a toss up. For a smaller rig I am sure they would have held up just fine. I machined the spacers as an exact copy of a Sky kit, so I can't badmouth the sky kit because it might be my machining that's off, but for my heavy pig it seems like everything is coming loose - the front knuckle studs keep coming loose, too.
Got a set of Rover 1 ton axles coming...
