I've got the big brake setup on the XJ done but I'm not happy with the pedal feel. It works well but the pedal travels much too far and I find it hard to modulate at the limit. My Jeep doesn't have ABS so that is just a little important.
I understand that the larger bore of a hydroboost master pushes much more fluid over a smaller range of travel (assuming same pedal ratio) and this is something that may fix me up.
So, what do you need to do to retrofit hydroboost on a vehicle that didn't...
