Straightening Dana 60 housing.
A
ajh
Can anyone recommend somewhere in town with a jig/press that can true up a Dana 60 axle housing? I've found a 5mm deviation forward on my left rear tube that I need to get corrected.
Thanks.
I can't help with a place that can do it but I've heard of guys laying a hot bead of weld to one side (opposite side it is bent) and letting the heat bend it back.
Both of the above if you want to try it yourself (good excuse to truss it), or I know Rockspyder does it although not really local.
I would call Malmberg for opinion, sometimes they are friendly and can recommend a good place; this actually happened to me once.
badcompany
bear with me hear guys but 5mm, it this so critical.....
I don't know enough about this stuff so im asking. with all the wheeling we do im sure no one has a perfect axes if they were all measured ... or am I wrong..
I dont know buddy ;) to each its own... one will keep driving until the wheels fall off, I on the other hand will go nuts if I know my axle is bent 5 mm.
A
ajh
Thanks, against all odds I seem to have located a replacement Salisbury so I should be able to remove this one and figure out what exactly is wrong once the other is put back together. In place I don't 'see' any bends, but the 4-wheel measurements are out enough.. I don't think a bent stub would do this without other serious symptoms like a seriously wobbling wheel.
