My truck is manly enough to have :rainbow: coloured O-rings. :flipoff:
Glad I called when I did, it is the one from the Belleville area.
The truck is in real nice shape, body has been rustproofed, there are only a few spot where the paint is chipped and one rust hole in the front fender. The interior too is very nice, drivers seat is a little worn but for 540,000km, I cant believe how nice it is. Front driveshaft needs a rebuild though, I think it was driven in 4WD on the road alot. 3.55 gears and and open rear differential......once its running reliably I'll swapp the limited from my '87 into it and maybe the lower gears.
So, how does it run?
I have a bunch of 1350 and 1410 slip yokes, flanges and other parts, if you want to give the dront driveshaft a whirl...
Are you asking me or Dirk?
I have zero Ford stuff, all I have is Spicer driveline stuff I have accumulated through the years (driveshafts).
Jimbog, I have an '88 10.25" dually rear axle. Its in my '87 right now but that truck will soon be parked and parted out. I don't think there's a difference from it to the years you mention, except the pinion length or something like that. What gears are in the truck right now? Is it 4wd? And rims would go with it, but not the rubber.![]()
I'd have a nice F350 if Dirk hadn't bought it out from under me :lmao:
Dirk I am still holding a grudge! :baby:
The 88 had a box, not cab and chassis, same frame width as yours. Dually rims are 16". How soon are you looking to do the swap? Are you planning to swap your gears & diff into the housing?
