Can I bring my 2500 psi Nitrogen tank?
Or what say we say screw it...ether...match..woof...done!
Your not saying that you will actually come to a meeting are you?
:beer::beer:
Me? Early?............hahahahahahaha....yeah right, nice thought but no such luck....I'm bringing 2 BFG MT's 31X10.50X15 on zuk rims......I'll have the valve cores out prior to arriving (as to allow both tires to be down to and equal zero pressure), and when we're ready for the test we'll put the cores back in and hook up each pump to each tire and let'em go for a prescribed amount of time, at which point we'll measure how much pressure is in each tire.....At that time we'll also check the heat generated from each unit...(looking for volunteer skin at that point...lol). As far as current draw, we could get one of the techo geeks to weigh in on the situation with some sort of device...ohm meter or whatnot....but I repeat I will not be able to make it there early......it's a given. See ya when I get there....
:beer::beer:
I'll bring a clamp-on ammeter but the positive and negative leads need to be separated. Only a problem if you plug in the cigarette lighter.
More importantly Matt, what is the cost difference.
