PROJECT - 86'd CJ
Mini-T
Sasquatch
1986 Jeep CJ7
That is what it looked like when I got it with a blown 4.2L.
So here is the plan so far.
Engine:
4.0L from 92 YJ replaced the dead 4.2L fed by a Mallory EFI pump
Tranny:
AX15 with hydraulic clutch from 92 YJ replaced the stock T5 with mechanical clutch
T-case:
Stock Dana 300 clocked up with an Advanced Adapter...
Mini-T
Sasquatch
Update July 8, 2008
_______________________________________________
Wheels and tires
Frame with most of the holes patched up. My goal is to have only a few holes in the frame that are sealed with boat drain plugs. Then Krown the shit out of it inside.
Drain plug
3/16" frame plates for the outer sides of the rear frame rails. I'll be making some that fit on the inner sides using these as a template.
Mini-T
Sasquatch
Bought them from Mountain Off-Road Enterprises. Looking back I could have just traced them myself and then had them cut out. I figured that the fit would be better and it came with a pair of short plates that run on the bottom of the rail at the end of the frame.
New body
Aqualu Ind. CJ7 body, .156" all over with some 1/4" and 3/8" reinforcing in places. The pictures don't come close to doing it justice. I'll try to grab some better pics when I start mocking it up.
Cool find!
There is a primer (no pun) on this at the PBB by Gui but not having to wade through all the BS at PBB makes your link great!
There is some other stuff you may want to try. It's called "Noize-Killer" and is supposed to help with noise AND heat. Ceramic beads in it or something. IIRC it's somewhat expensive but easy to apply and works.
Mini-T
Sasquatch
Natural is cool, but its not me. I think that flat black panels with gloss or semi-gloss accessories(headlight bezels, hinges, latches, mirrors, etc.) will look good.
That site was started by a guy who did his car after reading it on a Mopar forum. The 69 Charger was done by the guy who posted how he did it. It caught on from there.
You probably know already - but just in case...
You need a special primer for aluminum. Has to have zinc chromate or something in it to make it stick to the metal long term. When you buy your materials make sure the guy selling knows what you are shooting on to.
Mini-T
Sasquatch
So far I'm planning to use POR15's Metal Ready in the prep for paint. It etches and leaves a zinc phosphate coating that promotes adhesion.
Tremclad covers everything I want in my exterior finish. Flat finish, easy to touch up, readily available, and decently tough.
x2 on natural. Just clearcoat it.
Future plans:
4:1 gears
Spring over Toyota axles with 35s
ARBs
why not something a little stronger? 9" or 44 maybe?
9" from a classic Bronco is only 1" off in width.
Sweet body tho.....errhhh....the Jeep. :flipoff:
Make sure the POR-15 stuff is compatible with aluminum. I don't know one way or the other; all I know is that there are different materials for painting aluminum versus steel. The Land Rover guys know this stuff - maybe J-L will have some input.
Toy axle is arguably stronger than a Dana 44. Realistically probably a wash. 9" is way stronger then either though.
Yup, 44's not stronger... Dana's should start at 60's :flipoff:
And good luck finding a pair of 9" for $250.00 :lmao::stir:
FJ60 axles might be around for that price range though...
Probably land anchors on 33" tires though? Need to run something like a Qtrac or Dana 18 too.
Mini-T
Sasquatch
why not something a little stronger? 9" or 44 maybe? 9" from a classic Bronco is only 1" off in width.
This is a daily driver so for the off-roading that this Jeep will be doing I think the Toys will give me the strength I need at a decent size. The IFS rear and a widened SA front will give me an extra 2 1/2". Longfields take care of the front, and even Adrian is still using stock rear shafts.
POR15 lists Metal Ready as a must before applying POR15 to aluminum.
So what will the WMS of the front and rear axles end up at?
58" rear and 60.5" front?
Sounds about perfect for the build you are doing. Little narrower in the rear will make it stable at speed and help with tight turning on the trail.
Can the Toy front be modified to turn as tight as a Dana? How do you widen the front? Is that the IFS hub kit I heard someone mention on another thread?
Mini-T
Sasquatch
About 58" - 58 1/2" front and rear vs. the 56" front and 54.5" rear that came stock.
I'm not sure about the turning radius, I'm sure Adrian will let us know. Yes you use the IFS hub spacers.
