I am over due an update. As always, thanks to Andrew for all the long hours. And thank you to Mike I and Tim for dropping in occasionally to see how things were going and to lend a hand.
After deciding not to go with the 203/205 doubler, I called up North West Fab and had them send me out a black box. The black box is an underdrive with 2.72:1 ratio. This will essentially give me 1:1, 2:1, 3:1, and 5:1 ratio's (technically 4.68:1). Crawl ratio is now ~78. I had great service from NWF, always got someone on the phone when I called, and they rushed my order to get me an un-anodized black box assembled and out the door in three business days. I also ordered triple cable shifters from them as well.
After driving it shortly for two days at WAC, I was very happy with the new changes. 5:1 is pretty awesome, reverse shift pattern is nice too. I am looking forward to Phil Factor and Rausch later in the season!
You can virtually get 360 degree clocking out of one of these. We disassembled and rotated the halves to get the clocking we wanted.
Buggy gutted:
Because the driver side exhaust was going to be in the way of the new side mount for the transfer case, re-doing the exhaust got bumped up to this year. Andrew fabbed it, I poorly welded it
New side mount for the np205:
Andrew shortening the tail shaft on the transmission:
New shifter (Winters, reverse gate pattern), the triple shifters, and the rear steer valve re-mounted.
Rebuilt drive shafts and a new hanger bearing mount for the rear:
