Ooooooohhh gaawwd! Lol! Practice makes perfect!
As far as a wobble Turing right goes, I'd be looking at a bad CV joint or maybe a shifted belt in a tire, or a bent rim. But seeing as you're running aluminum rims, I doubt ones bent. I've also experienced that with a seizing caliper dragging on a warped rotor... Good luck Sir!
Sent from my iPad using Tapatalk
[MENTION=63]Kunker[/MENTION] I wish...but it doesn't really show all of the damage.
1 roller is shot (bearings fell apart, replaced a different one last year), 2 are bent very badly, both rails are bent in various ways, one panel is split at one side, one spring is broken and a cable snapped also. The remote no longer works (pooped out about 5 yrs ago). Pretty much all of the wood joints have been separating over the last 3 or so years too (you could see the whole thing come apart at the seams as it went up). When I went to close it last night to fix it, the one roller had already given up the ghost so I was 'helping it' follow the track. Bad move. I should have left it. It jammed and then went up and down violently 4 times before I could get to the master switch...it's a solid wood door so I think the weight didn't help.
Soooooooooooo......lol I think it's time. I've though about it a lot and I think it will need at least a full day of DIY work to fix and I really can't have it sitting open until the weekend with all the tools and sh!t in there. Plus at the end of that, it will not be a whole lot better. So, I think we're going with a new one.
Yeah, the difference between our old solid wood door and the new insulated one is night and day in terms of weight, and a lot less money than I expected.
"Quel domage" no better excuse to install a beauty insulated replacement with a couple of light shedders along the upper panel. Oh and one of those fancy battery backup heavy duty shaft drive openers!
In the mean time can you back off he other spring, pop out that bum roller and screw it shut?
We just repaired it. $226 later and it's 'all good' ...for the next couple years. It's a 16x8 (non-standard) so it would've taken a while to get a new door; the quote for the basic insulated one was $2100. Will have to order one in advance.
That sounds very strange indeed, I could see maybe a bad control arm bushing, a large difference between front tire pressures, or possibly a very worn out ball joint, inner or outer tie rod. Possibly even a blown front wheel bearing.
A caliper would not discriminate between 2 and 4wd.
Wow, detailed. I need another coffee to understand that lol! I read up on caster yesterday thinking it may be the problem too, but I got pretty confused!!! Wish I had the chance to stop in at the meeting last night (daughter had a band concert).
Yesterday I noticed when parked and wheels turned driver, that the wheels looks like \ / but not quite so exaggerated. When wheels are straight they are totally vertical.
Haven't had a chance to crawl under it - this weekend though.
