So I got my 220 hooked up in the garage this morning - so it's miller time!
I made and welded in some brackets (didn't get pics) that connect the bolts holding the fuel cell staps to the rear crossmember.
I finished the brackets for the hydro ram (welding with it all in the vehicle sucked) and layed down some paint.
Ram installed and lookin good...
Next, i started measuring to fab up a T-case skid until i realized that i could probably modify the WARN XJ skid that i have, it took some brain power but i realized that by luck if i rotated the skid 90* and alittle fabin it would work. Here i just welded on a tab for the front crossmember...
Then i just drilled and tapped both crossmembers utilizing 3 of the hole already in the skid and oula!...
I also started taping off and sanding for paint the rear area that was cut for some bedliner, minus the areas that i will be welding tabs to attach the cage and the body.
