Thought i'd update...
So spring fever was fun! but my "shake out run" identified some issues.
Bad tranny cooler line routing (which was fixed on the trail once the fan ate through it, thanks to all that helped!)
broken traction bar in the rear(causing bad spring wrap under torque)
not happy with front end geometry
a few electrical gremlins
So, i reworked the entire front end. I moved and rebuilt the track bar (bad joint on frame end) and located it higher on the axle. I also lfted the front end slightly with different springs (everything was too tightly packaged and when zipping down fire roads there was some contact at full bump)
Installed limiting straps on the front end too.
I stitched together the traction bar for the rear (used heavy angle iron) but that is temporary.. yes, time for a 4 link. I'm going with Johnny joints (like the front) and they'll be here tomorrow. I'll be going with a double triangulated set up so no track bar.
I'll post some pics tomorrow, i will be disapearing for work for a short time but plan on starting the 4 link in about 2 to 3 weeks.
