Now i can focus on the front, after alot of measurments and using the 44 as a template i started melting on brackets, passenger lower mount...
The drivers side wasn't so easy. I cut almost an inch off of the cast leaf mount to make some room, then cut out enough to properly place the lower mount. This time around I angled these mounts alittle higher as to not have them hanging down too low, the bolt holes are just below the center line of the axle tube...
Then fitted the upper 3rd link mount, even though the lowers are higher, this mount enabled me too maintain 8"s separation...
added a brace to lock it down...
