Build Project - SS Cherokee
mucovich
Till Valhalla!
Thanks George!
Cut up some of the aluminum panels last week, trying to use up all the extra stuff I had laying around the garage. Dropped off the TH400 at the tranny builders this afternoon and picked up the mock up block, near the end of next week I figure i'll pick up some sticks of DOM and start building the front part of the chassis. I've got some designs in mind although I'm planning not to deviate too far from the design I cut off. Really liking the look of the Trent Fab "top shelf" chassis, fairly similar.
Impact
Over the top that's for sure! Sure has come along way since I first saw that beautiful XJ!
Where are you having the tranny done?
How are JP's and Chad's TJs coming along??
mucovich
Till Valhalla!
A guy in Renfrew, retired tranny guy who does trannies or a local race team. Chads is done, him and his old lady daily drive it. JPs is done to, he had a lot of issues this year though, motor caught on fire at Rausch (caused a fair amount of damage then as soon as he got that fixed he broke the output shaft in the transmission. All is fixed, and he'll be ready for spring.
mucovich
Till Valhalla!
Thought I would put together the mock-up motor after work today.
mucovich
Till Valhalla!
Cleaned up years of oil and dirt off of the fire wall and threw down some paint, bolted up the dash panel and started to play around with the layout, ATLAS is 95% ready to be bolted up to the tranny when it gets back and tossed the wheels on the front to get an idea of how she looks so far.
mucovich
Till Valhalla!
Got busy today - I received the steering shaft from poly and started bending up some rails. Then I got the fairlead bracket glued in place. It's a good start!
mucovich
Till Valhalla!
More updates... mocked up the suspension and winch...
mucovich
Till Valhalla!
Big time!!!!
Got some tube work done today, starting to look like a buggy again...
mucovich
Till Valhalla!
Thanks!
Wow, I've been putting in the overtime in the garage lately! Gotta get stuff done when I can. Pretty much finished tubing the front end - I had to represent with the small chevy emblem - subtle. Also got the engine cage in place - i'll be cutting the tube and taking out some of it to replace it with these interlocking tube clamps I got from TMR a while back. it's looking better then I had envisioned - final welding everything in going to be a pain!
mucovich
Till Valhalla!
more... and ignore the headers that I threw on the block - they are just there to check how much clearance between them and the chassis - lots of room.
Fakkkk... Thats some really nice work marek.
Sent from my iPad using Tapatalk HD
I really like that:
:smokin:
