front drive shaft
We worked on the front drive shaft design yesterday.
to achieve a longer slip we used some agricultural pto shaft parts.
After much time spent at the tractor dealer we found the best deal on parts at TSC.
Instaed of using a square outer shaft we opted for a square slip joint. This is what most AG equipment is going to.
We'll reuse the Cherokee front shaft, cut off the factory slip joint, and rplaced it with the square slip joint. We also cut the yoke of anothe slip joint and will have the splined hole machined square today. Tis will allow the 1 3/16" square shaft to slide into it and be welded on both sides.
This will result in a shaft with 13" of movement while maintaining all 5" of spline contact.
