Alright, well I have done lots of cutting and welding but have been to busy to post any of it.
To start off a big thanks to Matt, Scott and my Dad for their help as I would never have got done at all without them. (yeah and I was 3 days late to Lingham anyway)
So the cutting:
I only cut one side off in the first place so I would have a reference for the first side. I picked an arbitrary point in the centre of the truck to base my calculations for the Bend-Tech program and then used a level and screws in the old body to determine the line I wanted the tube to follow. Yes I was told I was being to complicated but I want people to look at this when I am done and say: "Hey that is a Cherokee", everybody had their nutjob visions and that is mine.
Alright the cutting begins
And the bending. I left the blurry picture of me bending as it seems to be a precursor to how my learning curve with bending will go.
So I bend my first piece of tube (besides some inner fender hoops I made so that I "understood" :lmao: the bender and to calibrate it.
Note that the tube on the top is bent at the totally wrong place. Thought I saw a mark, missed the other mark, shouldn't do winter projects in a rush in 1 week and stay up every night past 1 and some nights 3 and 4 am. Whatever I screwed up.
So after losing my mind over such a waste of DOM I sat down and calculated where I could use pretty well every piece of it for other parts of the cage in fenders front and rear and braces etc.
Then I bent a new piece. Note to self do not leave other similar types of tube lying around when you are tired and in a rush or you will pick it up and bend it. That is why it is a different colour, not that much of a different colour but enough. Also when Scott pointed out that it had a seam on the inside and I noticed it bent different in the bender (1.66 pipe compared to 1.75 Dom DOH!!!)
Also note that both bottom legs of the hoop are pointed to the left whereas they should both be pointed in (1 left, 1 right) which will come back to haunt me later.
Matt came back out to help me again and cut the rest of the back off and we also removed the rear "crossmember" and put my bumper in it's place which gained me 4 inches on departure and much more strength across the back of the truck.
The pile in front was what the back of a Cherokee looks like when it is cut off and the pile of dirt and rust (which looks much bigger in real life) is what fell off the XJ when it was cut apart
At this point I had temporarily abandoned the hoop as I was "thinking" about what to do.
Scott came out and we bent up one of the sides which were "harder" :banghead: to do which is why I did the hoop in the first place.
So what I ended up doing was cutting the first messed up hoop just above the problem area.
Then bent a new piece using the (incorrect) 1.66" pipe as a template.
issed:
To ensure that the joint was strong I sleeved it with 1.50" DOM 1 inch inside of each pipe with 1/2" showing for a good weld so the joints are actually the strongest points lol.
More later I have to go work on the Bus for NH so more so I can work on the truck for Chertsey. That was my lunch break lol.
dj
So the cutting:
dj
