dougiet
Thanks, guys.
It is a good base to restore with.
I watch YJ's on Youtube offroading and notice they bounce around like strippers on a Saturday night, is there an aftermarket tuned suspension kit install that could keep the jeep planted, or is it a combo of name brand components to get up over and onward.
Planning a spring retrofit of the suspension with steering, driveline, axle rebuild, and axle gear ratios upgrades to combine with 33-inch tires. Not sure of the ride height inches and gearing ratios so there is time to search over the winter and determine all of the above.
Right now the lift is 3 1/2 inches on 33's. The tires, ujonts, tie rods ends and steering bars could fail a certification. Planning to get set up and do it all.
Ordered a 2150 carb with a 1.08 venturi with #49 main jets. The Sniper carb kit will wait until some miles are driven to get an idea if the motor has power or is a rebuild. It idles well but spits and sputters in a gear under throttle. The thermostat now is at 195 degrees with no failures with this pressure on the motor.
Will change the tranny oil filter and a timing chain re re install. Soaked the cat in a 5 gal pail of soapy water for a couple of days and the exhaust is flowing well.
I am sure you guys have heard this a hundred times over.
