IT HAS 4X4!!!! I'll get the poser shots out of the way first, keep in mind that my front isn't flexed out. Tape measure says 6" of travel left up front, while the rear is maxed. Check out the fenders, Garth Fisher formed them for me and tacked them in, I have to weld and paint etc still but I love um.
So I started by building my third, its a Sami rear chunk, kick front carrier, kick rear side gears (for the 26 spline), all regear to kick 5.13:1 gears. Handy tip for building diffs adjuster wrench comes with your grinder!
I'll throw in some pics I took of the front diff housing, its a sami rear center section, cut and the sides closed in using the flanges cut off kick front spindles. This gives me a nice bushing at the edge of the housing to support the shaft also allows me to easily use kick outer stubs at the center too. They are 26 spline and they also have a better travel range.
The extended shafts are cut and keyed together, welded, then sleeved with a tube cut in half lengthwise so it could be welded to the shaft along the length of the sleeve. 4000 rpm clutch drops in 4 low on gravel, spins all four no failure. So it might hold up.
Then I extended the drive shaft. Stock shaft is basically 1.5" o.d. 0.120" wall tube, so I cut it and sleeved on some 1.75"o.d. 0.120" wall DOM. The sleeve goes full length yoke to yoke. then double pass welded.
First pass
Second pass
Lots of body work and gusseting to do, but she runs and its great so I'll slowly tackle the odd stuff that remains.
SPECS.
Lower arm pivot angle 3* from horizontal.
Upper arm pivot angle 13* from horizontal. prevent brake dive
Castor 12* at ride height
Chamber -1* at ride height
12" of travel restricted by shocks and bumps
Lower arm length 22" pivot to pivot
Upper arm length 19" pivot to pivot
Coils, 94 f-150 2wd with a 302 approx 360psi spring rate
shocks, monroe 37044 approx 10.5" travel
And BOOM, but wait there will be more!!!!
