K
KBjeep
Ok its a hp30 with tj axle vac bypass wheres the ps seal?
Not that familiar to be honest with the vacuum disconnect models other than I avoided it when looking for my HP Dana 30. The only difference that was a negative is the original shafts uses a smaller u-joint while the non-disconnect used the same ones as the TJ and it was one less thing to deal with. Rumour has it that the disconnect housing is a bit more sturdy than the non disconnect but that is just rumour and hearsay. Plus we are talking Dana 30's.![]()
I am batman don't tell anyone elseHoly fast replies batman!! Lol!!
I decided to leave the seal out of the vacuum housing. I cant see a machined surface in the middle of the tj shaft.
