Logan redneck/backyard/halffast build...
Logan
apparently the prezident
Someone on another forum was saying the rear xj shaft have one, and couldent get a clear answer on google. Im going to the junk yard to hunt for one today. Figure id try it out instead of waiting to get my drive shaft lengthened... I need it 32" long.
DoctorPhate
The rear has a standard slip yoke with a single u joint on each end. it was like this for all models and years. The person who told you this was confused, they most likely bought one from someone that had a front ds in the rear and a SYE or hack n tap in it.
Speaking of which, you can do that, hack n tap from RE is 100$ and a front DS in the rear.
Logan
wtf is that? To get my d.s. lenghtand with a new tube, and u-jointsis only $100-150. I think ill just go that route. I was hoping for a cheaper solution for now, untill I finish everything else.
DoctorPhate
Hack n tap is basically an SYE. This way you can upgrade to SYE right away.
hmmm, it just so happens i have a 231 with RE hack and tap for sale (haven't posted it up yet) with the flange for the drive shaft
Logan
Ill count it in a little bit. Ok...
I have the stock 1998 XJ steering assembly. The tie rod that goes from the right knuckle to the pitman arm, and the tie rod that goes to the left knuckle connects to it. I need one about an inch shorter. Are the yj.s shorter, or should I cut it, and sleeve it to the length I want???
DoctorPhate
cut and sleeve, its just easier whether the YJ is shorter or not. If you got it, use it. Let me know if you need help with anything, I'm off most of next week too.
Using the DC drive shaft or not is dependant on the pinion angle -- or the pinion angle depends on the driveshaft -- depends if you are a chicken or egg kind of guy.
If you have standard u-joints at each end of the shaft, you want the pinion angle and the rear output of the tcase to be euqal and opposite of eachother (paralell when viewed from the side) This is so that the u-joints cancel each other out to eliminate vibes caused by the fact that there are minor but distinct changes in speed as the u-joint rotates at an angle.
If using a DC shaft you want the pinion pointing directly at the rear output so the standard u-joint at the diff has no angle to it while at ride height. The DC joint isn't affected by the speed changes like a single u-joint is and is designed to handle all of the angle (within reason) that you'll need at ride height.
The SYE is good for a few reasons: 1) If you blow a rear DS on the trail, you can remove it and continue in front drive without pissing all the fluid out of the tcase. 2) You have the ability to have a longer ds, usually important on a SWB vehicle. 3) A slip shaft is much more durable and easier to maintain on a trail rig than a slip yolk.
Logan
yea....the rear pinion is pointing at the tranny...my bad on that one. barley vibrates though. lol
Logan
So anyone have a cardan lying around???
But I don't understand how you are going to attach it to a NP231?? And those usually go for at least $100 out of an XJ as I think they are close to a bolt in for TJ's.....Scott knows those details. I have some, and depending on the length you need I have cut ones, but I am not sure what I want to sell if any.
dj
Logan
I just need the piece that links the shaft to the flange. Pretty much jest to lengthen the drive shaft 2-3" enough to finish lifting the rear. Im eventually getting a sye. But I need to do more research on it. Seems that everything converts it to a dodge speed gear. I have the electric speedo, so I am not sure what all I have to do. Maybe ill go pull one off at union. One of the guys has been giving me amazing deals for my project.
I dont know if im just misunderstanding, or not wording it right.
Ya that won't work on the rear of a 231 without a SYE or a hack and tap. Yes the shaft you showed comes in the front of XJ's and they go for 100 a piece. I have one but I don't want to sell it as I am going to make a spare rear shaft for my jeep. (I have a dana 300 so it works for me).
Unless the chevy 231's came with a double cardegan rear. That I don't know.
Logan
wtf is hak and tap... I still dont understand what that it...maybe ill drive it this weekend to ottawa truck, and stall shackles, and lengthen the driveshaft there. I think that might be easier. then Shim the rear end for the right angle till I do SYE.
DoctorPhate
You're looking to put the Slip yoke on the end right logan? I dont think it would be stable if you did. Dont ask me why I just feel like its right. lol if it works though you may have just saved a lot of people a lot of money.
