Planning on siphoning the gas and using it in the Liberty to drop the weight on it. Told Anne that she has been conscripted to guide the filler neck up when I put it back in.
Pulled it this afternoon and it went so fast that after dinner I proceeded to chop off the old brackets
Above is the driver side. Suprisingly the steel is pretty much still there. Still going to stab at it tomorrow and weld in some replacement steel.
Passenger side was not as nice. The thing with that hole was how the bracket ripped itself off. I am going to have to see if I can get the muffler disconnected from the cat. The clamp that is there is seriously rusted on so obviously will need to be replaced.
Had a couple minutes this evening and got the Gas Tank skid together. Decided to go with having it at its highest height since I have a Body Lift already (almost like it was planned or something...)
Brad, You wouldn't happen to have a strap wrench that is big enough to loosen the fuel pump ring would you? PM me.
