Actually got some stuff done today, may hear about it from the wife since the inlaws were coming over for Zombie Jesus day. Brakes are on but I seem to have misplaced the short hard line on the axle in the mess that is my garage. If I had it I could have at least got the rear brakes bled. Other stuff I did:
Hard brake line to the rear has been attached. I had bought a small brake line that I cut and attached to the one I have to find and it it acting as a plug
Passenger shock is on, I can't do the driver side as I have to move the small bracket as there is interference with the shock.
Ran the rear locker line and attached it. Leak free as it held without the compressor kicking on.
Will have to adjust the pinion a bit. If you recall I had put the jeep at the height it is normally at with the Dana 35. With the 8.8 under it, it sits higher. Shouldn't take too long and is probably a degree if that.
