Dragged it outside and put it underneath and made sure I had adequate clearance between exhaust and gas tank and it all was nice.
Lots of clearance (well the minimum is 1/4" between the gas tank and diff cover). I will probably have even more when I get the Savvy Gas Tank Skid on. My concern regarding the truss hitting the exhaust ends up being nothing as the coil plate hits the bump stop before it.
Next step is weld it all together and plumb and paint it. I also checked with the new flexible brake line if I had to figure out where to attach it and looks like it is pretty flexible (pun not intended) on placement. I think it is because the truss makes it closer to the frame so less line is needed.
Right now the big issue I will have is welding on the top of the new bracket on the passenger side since the muffler is in the way. I think I can move the muffler out of the way otherwise I may end up just cutting it off and reattaching it.
