Well the buggy worked great at Spring Fever, better than my expectations, very stable on side slopes, and steep inclines. Just a couple issues to work out, need to rebuild my rear shocks, and add a bit more oil. They were bottoming out all the time. Had a brake line fitting hitting on the front upper link bar, easy fix, bought a 90 degree fitting to clear it, going to have to bleed the brakes again!! Going to re-connect my line lock again at the same time. Front pass tire bead lock is leaking at my welds, just slow leak( but a pain in the ass just the same) have to take the tire off the rim and grind down the weld and re weld it. I wish there was a way to check it before re-assembling the tire and rim. No problem running the 39.5 tires with the gearing I have in low range, high range is a bit sluggish though. So I will stay off the highways. Wheel travel was great! don't think I ever had a tire leave the ground, if I did it was the 2 front tires at the same time! Did Craig Lake all the way through, it is a tight trail for a truck axle 92" wide, but doable when you don't have to worry about body damage.
