Well, i had a day to myself so i focussed on finishing up the rear. I pulled the rear out, primed it up, then shot with a few coats of rustoleum. I then tackled the frame mounted rear coil brackets. I never liked the way the rear coils were on such a nasty angle so i picked up a relocation bracket kit from Rusty's and started in on the installation. It was a dirty spot to get to in removing the old one however once out it went quite well.
I then had a hell of a time getting some bump stops in place because of the variances through the chain on bolt sizes and corresponding holes!! I ended up hacking off the end of these Allen head bolts and welding them to threaded rod. That allowed the bolt to make it through the bump stop but still thread into the relocation bracket up top..
I am now on to the Transfer case. I need to pull it and remove the existing SYE and then install:
Tera Extreme Short SYE
Tera 4:1
Tera 2lo
Once this is in progress, i can then paint the skid plate and weld in some plate on the bottom of the frame to replace those rivnuts.....
Left to do:
Tie up the brakes
Finish welding the frame side CA mounts
Get a new Driveshaft
Tie in the rear bench seat
Figure out what to do with the front seats
Make some harness bars
Hook up the seatbelts
Finish my front hoop/stinger
Set up the ARB and lines
Misc bunch of other crap....
Good Times.
