Did you draw the flippoff guy? Or did you import him some how?
I just drew him. Mike had to make some changes though so it would cut properly.
That's looks like it's going to provide excessive braking power and I don't see any need for that, I think you are getting out of control with this build.
Heretic!
Yeah, XJ brakes suck. I had to upgrade mine because I couldn't stand how bad they were - even when the Jeep was stock.
Adrian, what's the plan for the proportioning valve?
Seems to me as though the ram will bend the bolt.
just curious why you can't use a double ended ram? Then you could attach direct to the knuckles.
The only way the bolt can bend is in an arc perpendicular to the bottom brace (It could rotate in the bending motion)
If I weld the bottom brace to the tubing and weld a second brace at the top of the tubing going to the tie rod hole, it would eliminate the rotation that the bottom brace could have and then eliminate the possibility of the bolt bending.
That being said, Dirk has the same problem I usually do, over building things![]()
I looked up some numbers last night. The ram comes with a 3/4" joint that is rated to 11,000 lbs - The yield strength on a grade 8 bolt is 120,000 lbs. Not to mention that the force that could bend that bolt is split up into two vectors, only about half going in the direction needed to bend the bolt and it also has to bend the tube sleeve as well. Dirk - How many lbs of force could that 2.5" ram put out?
Oh Adrian, Connie found your windshield in the ditch today, she said she actually first saw it about a week ago whether it had been under weeds until then or somebody has cleaned the ditch recently and put it over by the fence. :beer:
