3 wheel drive on the Gorge caused me to be mad and drive like a tard and then break my tie rod, not bend but break in 2.
Well I pulled the hub off of the driver side I found that the Warn hub;s retaining clip had expanded and had let the clutch pop out. Oh I said good that is my problem not the locker. I also took the other side part to confirm that I had both hubs correct and actually had to go to Napa who gave me a new set up hubs per Warn's warranty. Nice, I actually only took the clips off the new hubs as my outers are kind of marked from badly placed rocks on the trail and I didn't want them claiming abuse.
Put both sides back together, wheel back on driver side and..........grrrr a skipping side still.
So then I took both sides completely apart, inspected RCV shafts with nothing wrong with them and pulled the Grizzly which doesn't show anything apparently as stripped splines.
So then I semi put it back together so I could watch the Grizzly and shaft spin and put it in front wheel drive with one tire on to see what was going on
http://www.youtube.com/watch?v=VATXexjsyUM&list=UUO9abV_R7LnN5GaLOCScNtw&index=2&feature=plcp
That noise is not my engine or exhaust but the noise of a Grizzly skipping.
Nice, I look up warranty and it is 1 year. Hmmmmm 2 years old I will be talking to them. The Detroit in the back I have had for 4 years and the guy before me had it for years including time under a Jeep with 37's and he was a WOT guy and he bought it used.
