Little update...
Was sick as a dog for almost 2 weeks so lost allot of shop time.. But as soon as i could i got some time in over the last week or so.
Put together my beadlocks.. Was surprisingly very easy. Tedious as heck but once the 130 or so bolts were torqued 4+ times, i was good to go
Then started working on the front suspension.. Had to notch the HEMI skid plate to setup the front CA's. Still need to center it all and tighten down the bolts but so far it looks good:
Lined up the motor mounts and welded them in:
Then started tackling the inch or so of undercoating that covers the firewall...:
Questions for the edumacated!!!
- I was looking at the alignment for the shock mounts for the fronts.. Currently there are axle shock mounts setup on the backside of the axle tubes, which i find when i set the axle in place, is not well centered on the upward arch of the frame.. Does anyone see this as a concern? It'll imply that the strut will sit at an angle towards the front at the top. Alternatively, i am thinking of welding on some tabs directly on that top plate in the pic (Where the coil spring mounts were), which will set the struts vertical to the top mount, once i weld them both in.....
Question:
- Where's the best place locally to price out new brakes? I THINK i have 1/2 ton chevy calipers for the rears and fronts.. Can anyone confirm this?
I also need 14 bolt lug bolts and lug nuts for both a 14 bolt and a snowfighter D60. Does anyone by chance have part numbers for these? I have been having a hard time finding these as well with certainty...
