Question....  I had to build my own tranny mount as i wanted support while pulling the skid plate.  I went with a universal setup from TMR and then adapted a teraflex plate made to fit the 545RFE tranny.  Problem was that the actual teraflex plate mount would not allow clearance to clock the ATLAS.  So what i did was i removed the actual polyurethane block and then clipped the plate in half.  I then mounted that to the TMR setup, which ties in to each frame rail with poly bushings...
will the poly bushings on each end of the tranny mount be sufficient enough flex to accommodate the movement?
Some pics below for reference..
Cheers,
Cheers,
