Best to try bad male fitting with a new female fitting/VI's versa. Clean up the thread, and have both fittings in your hand and fully seat. Happens all the time when laying down gas pipe. Then again, it's malleable black iron...
yeah lube is always good. I wonder if I used a normal nut just for setup if it would be OK or would that potentially screw up the threads more.
It looks like the nut you were using was a mechanical locking nut they damage the thread slightly when used, anti seize will not help you there. Either find a regular nut or a nylock for testing.
Got my new ring and pinion and noticed a difference.
This is the original Ring Gear I got:
This is the new one (note the gold lettering and the gold block)
Both came in Yukon boxes and looked like the boxes hadn't been tampered with.
Thanks Danny, I figured that was the case.
Back on subject:
Pinion depth (~60 I can't remember but will get it if I need to redo)
RG: 0.035
NRG: 0.060
I thought it looks better. The BL is about 0.008.
Opinions?
Also the one thing I have not definitively found is what torque to put the Pinion nut to. The Dana manual is definitely wrong it is saying like 400ftlbs. The only thing I have seen regarding Dana 30s with Shim packs is 210 ftlbs.
