Thanks to John & his press, the t-case got rebuilt over the last week.
Spent about 15 hrs at the shop yesterday and things are looking good.
Forgot to take the camera though :banghead::banghead: so no pics
Installed the rear shocks
Re-installed t-case/driveshafts
Installed twin stick
Re-routed exhaust
Re-mounted 2 tires (hopefully no leaks this time)
Massaged the firewall for tire clearance (BFH)
Installed Hi-steer
Installed rear tow hook
Bled brakes
And......
IT RUNS!!!!!
Took it for a quick spin down the lane and thru the ditch. Rear suspension works really well, 24" plus of wheel travel, no obvious binding or rubbing anywhere. Front is a different story.
Front tires hit the springs when turned. I'll have to get some wheel spacers but for now I'll just adjust the steering stops to limit it. Tires also still hit the firewall, I'll have to try to find some more room for them, either move the axle a bit forward or cut out & move back some of the firewall or both.
The other problem is that the drag link hits the oil pan when the front right wheel compresses. Any one know if I can section the oil pan for clearance? Probalby extend the bump stop for now so I don't break anything but that is only a band-aid.
I also need to bleed the brakes some more and re-sleive the rear links otherwise the truck is ready for Spring Fever :smokin:
:smokin:
