Yeah unfortunately it is, why do you ask...? My interest has been piqued... I say unfortunately b/c apparently there are only a few OEM 15" wheels in that pattern that work together with the coilover front susp and the discs.
As far as 16" OEM, TJ Moabs would work, but they are few and far between...saw one earlier this winter for $250 and should have jumped on them, but it wasn't a good time $-wise. I believe other 16s require spacers or I would need to deal with some rub at lock.
I thought of 265/75/16 but was thinking with how light it is, the 245s would cut better in snow/mud etc. Am I off-base? Plus as they are a bit bigger than the 31 above, I'd have to double check but the 265s on my stock wheels may rub on the sway without a spacer. I'm honestly ok with either option, just want to make it as budget-y as possible. I'm also feeling that with 3.73s I may just kill my gas mileage even more...currently only get about 300 kms to a 60L tank usually in 4FT, but I like to accelerate (bad habit).
I'm sure many would say the same: there is a list of things I need to do, plus a long list of what I'd like to do.![]()
You were right, I hate that style of measurement, I so prefer the way older way where you didn't have to do math. However stock TJ came with a 9.5" wide tire on 8" rim but yeah if airing down you may risk slipping the bead235/85/16 is more like just under 32 by approx 9.5, i would not recommend an 8 inch rim on the pizza cutters. 7 would be ideal for that size. gotta love the pizza cutters, a good trade off for extra clearance yet saving weight and wind resistance =
If you are looking for new rims, go 17's and future proof yourself. If you need more cheap options, Ford used the 4x4.5 pattern, so there are other options out there.
It already seems like a gas hog at 300 kms/60 L (winter...summer is more like 400) so don't want to make it unlikeable. It has 3.73s and iirc slightly taller gearing than the nv3550 so ya likely fine for power.
Maybe I'm overthinking this...(ya think?!??)
