Well... Today was a good day. I finally was ready and able to reconnect the drivetrain to the frame and button everything up. I had one heck of a time with the tranny to the engine. Fawk, i just couldn't get it to line up (Guess it does make a difference to have a tranny stand!!!). Then a note to all...... MAKE SURE you have the bottom splash plate correctly in place BEFORE you torque down the bolts securing the tranny to the engine. I learnt the hard way that this is required...
In any event, some photos of the results so far. Frame is completeley POR'ed, SYE is in place, everythings degreased sanded and/or repainted, all new gaskets and everythings connected back up. I had to grind off the rivnuts for the skid plate and insert new ones as the existings all spun loose. I then tack welded them in place so it should hold nicely. Next steps are to get the axles finished, then hook up the suspension and then get the wheels on!!
Thanks to Andrew for the TC oil pump. Fit like a glove. Just hope it works but i won't know that for a while yet
Thanks Richard for the clutch alignment tool Worked like a charm.
