Final Update on 1st stage of build
Well..... The time has come. I have pretty much completed what i wanted to get done (Minus the full cage) for this year.
I ended up replacing the rad with a new one (Thanks Keith!!) as the existing was pretty crappy.
I got the NOVAK TC shift kit installed and other than a few adjustments to make, it is very smooth and so much simpler than that OE setup.
Had a CV Driveshaft made up and reconnected my rear axle.
Brakes are all bled and secured and work well. I may have to rebuild the rears however am hoping i don't have to as i plan on swapping out the rear axle anyways
Replaced the visors from tan to Black to match the rest of the colors.
Had a nice 2.5" SS exhaust bent up for past the cat with a real nice sounding muffler. The tail pipe site a bit lower than i was hoping, however i just might live with it or perhaps take it back for alternatives.. We'll see.
My lad who was to build my custom cage had to delay due to an impending house move so it might not happen now till next year. In the interim, i painted up my existing cage in black and bolted it back up for now.
Regarding the engine, i was amazingly surprised that the ONLY problems i had were that i neglected to connect the wiring for the ignition AND there was a relay blown for the starter. EVERYTHING else worked as it should, which is incredible considering i literally had every single part apart to de-grease, etc.... It just blows my mind.
The ONLY downside i still have are issues with my LED's. I brought it to a shop and they advised me that it's my turn signal switch as it doubles as a multi-function switch for the lights and signals. It's been on back order now for over 2 weeks (And Cass.... Yup, with Car Canada....) with no end in sight.... As a result of this, i cannot get the TJ safetied. So, i am scowering the sites for a used one. IF i don't come across one locally by the end of the weekend, i just might buy one off eBay and take my chances.. We'll see.
I still have to get myself some D-ring shackles, some door surrounds and a soft top if i have any intentions of driving it late into the fall.
I hope to, over this coming winter swap out the axles for D44's with 4.88's and ARB's. We'll see how the funds co-operate
I was really hoping to get to use it more late in the summer but at the rate i am going and the fact that i have absolutely no top/uppers, i might now be looking at next year
Some final parting shots
