rear perches
I noticed a while ago that my rear pinion angle was getting worse. It started off properly, then it was 0 degrees, pinion shaft and driveshaft were inline. Then the pinion kept rotating upwards until it was about 5 - 6 degrees the opposite way.
Looking at my rear springs, its it plain to see that they are bent in front of the axle ...from gentle use.... which allowed the axle to rotate upwards, causing the pinion angle to change.
I knew I should have done something about it, but i went wheeling instead and ... broke the u-joint trying to climb a 30" vertical rock.
So I tore into it today and ground the welds holding the perches and noticed something peculiar. The perches were digging into the axle housing, crushing it.
Over a 1/4" intenation
The axle appears straight otherwise, only crushed in the perch area.
Since  I don't have another '86 or newer axle to swap in, I'll keep running it.
I plan to cut a section off another axle tube, split it lengthwise and use a half in each of the damaged areas to reinforce it.
Has anyone had this happend ever?
and before I forget...important safety tip...don't trust your jackstands on your gravel/clay driveway. :flipoff:
good thing I own a tractor with a loader.
