After thourough testing at Spring fever I have found a few deficiencies, but it performed well in most cases.
And came home in one piece...
I am very happy with the tires, even though I popped the outside bead on the right front on pinion pass on Sunday. They seem to work real well on rock and in soft mud/bog they did not dig down and bury the truck, yet kept moving me forward.
Climbing a hard berm out of a mudhole though, they seem to lack traction, probably because the tread is not very aggressive and is lacking big voids.
The Hydro pump chain drive also held up well. it is noisier than I would like. Knowing that it works, I will invest in good quality o-ring chain which should be quieter. It also required to be tensioned twice over 4 days, a better chain may require less maintenance.
As I fall into the supermod class for Spring Fever now, but the truck is obviously not on par with buggies or other coils sprung, high horsepower rigs, I was expecting to winch alot to get many flags. Our strategy was to start halfway through the course as to avoid traffic, which made flags 8 & 9 our starting point. Both are in the large bog, which this year was not traversable by many rigs, 2 of my team included, and slowed is down tremendously (2.5 hours).
I bet my clutch and tranny hates me for this:
But gave me the chance to test my winches. :clue:
As I couldn't get up the bern out of the swamp, I winched up, forwards. As expected the winch would not pull the truck in high gear, but I had to try to be sure.
A little later I got the chance to test the rear winch, but as I pulled the lever I dumped all my fluid on the ground in seconds. Seems I had one fitting only hand tight......
I was able to find 4 liters of ATF to dump into the reservoir which gave me power steering for the rest of the day, but kept me from using the winches. :banghead:
The electric fans worked well, I can run just on one and keep the temp below 200F. Even when flogging it really hard on the access roads the gauge barely went past that.
Crag lake trail doesnt seem to like the shape of my passenger fender and modified it some more, in addition to last year.
So after running the course on Friday, setting it up and trying some of the rocks. Doing the event on Saturday, Pinion pass Sunday and Crag Lake Monday....The truck saw 4 days of (ab)use and had no real mechanical failures.
Ofcourse I still have to go and test the winches, maybe The Gorge next Saturday for a quick run.
P.S.: Having tunes and a CB was real nice.
-----pics to come----
