Northumberland Offroad I think, saw it on DMR
dj
I'd be up for a run to Lavant on the 19th. Has anyone been in the last 3-4 weeks? Wondering if the water has gone down (or up) in that tough spot?
I was there a couple of weeks ago. The main water hole was quite high, swallowed the 44" boggers. The other mud hole in the middle of the trail was fine, we had a stock JK through.
Holy crap! I was hoping I could pass on that side. The last time I was out there I went through the mud hole in the middle of the trail with my stock JK (cracked the driverside running board) but I've since got a 3in lift and 35 inch tires so I'm hoping that should get me through without getting hung up this time but I'm worried I am too wide to avoid having to driving over both rocks at the same time. I've got 1 1/2" wheel spacers on now.
Shawn....... No need to be worried
If worse comes to worse, you could go up along the Left side and bypass the rocks but who wants to do that!!! Like Brad said, with 35's you are now going over the rocks
Good to see you back online too!
Is there a run this weekend?
Unfortunately, I have to pull out for the 19th do to an unexpected birthday party but I'm in for sure if there's a run the weekend of the 25th-26th. :banghead:
Sunday the 19th to Lavant.
Map link
Basically head west out of Ottawa on the 417, take the second March Road exit (it's after Carp Road/Hwy7, not in Kanata), turn left on March, follow this road until it ends and you're in Hopetown. I believe the meeting place is just down the 511 (turn right and park on the shoulder), but someone can correct me if I'm wrong.
