Learned a lot about the 231 between what Novak has (which has it all but not in their tech section) and pirate and Jeepforum.
- there are three shaft lengths of 231s involved with the Jeep line, short, medium, long.
- before 1994 the short length was used for the automatics and manual (AX-15)
- after 1994, the 231 converted to the long length for the manuals while the automatics remained at short
Now the other thing that changed was around 1994 the gear cut changed on the ring gear pressed in the case, the planetary gear that runs on the ring gear and the gearing on the input shaft which sits inside the planetary gear. It appears that the newer shaft will fit in the older planetary gear (the opposite is not true) and it has been reported to be noisy which implies there is excessive play between the two. Also the newer planetary gear will fit on the older ring gear but is a tight fit (see the next line why it seemed to be a tight fit.
Also at the same time the size of the bearing shrunk (if you look in the picture above the little landing which the input bearing rests on is taller on the long one. This is because the bearing on the newer model is about half the depth of the of the older model. So when putting the shaft back in it would get a bit in and then stop and I think that was when the landing touched the thicker bearing. I may be able to swap the bearings from each case but I wouldn't feel comfortable selling my old one then
I have put the original short shaft back in the doubler's 231 and will see how much it grabs tomorrow. However I have a strong feeling that it won't at all as I have also put on the flip ring which pushes it back making even less of the input shaft to sit on the transmissions output shaft.
The good news is Novak does carry a old style gear cut long output for thin bearing. Bad news is it is $167 but it is what it is so selling my old 231 with the stock shaft and the SYE should cover the cost.
