Actually, I made a mistake earlier. There's a TSB for the front wheel shimmy(wheels feel out of balance at high speed), which is caused by overweight tires. My FJ shakes with 35" tires at highway speeds, but is barely noticeable with 15oz of balancing beads. Toyota's solution is to drop the rack and pinion and replacing an internal spring. It also seems that it's corporate policy to blame the customer for installing heavy or unbalanced tires before admitting to the TSB. Brand spanking new FJTT's or FJUE's will shimmy right off the lot with factory installed BFG's and shimmy, which lead to the TSB.
Again, I'm correcting myself, there is
NO TSB or recall for the Transmission, but there are hundreds, probably thousands of people with the affected problem. If you will read my
source, you will see that Toyota is playing dumb on this expensive issue, and many tranny shops are working on A750E transmissions for this same reason. My truck has been through a full flush with Lubegard aadditive with no positive results. I've researched this issue to death in 2012-2013 with no interaction with OVO, as I am the only one with a late model Toyota, and this is mostly a design fault. It's also the same reason there's no FJ build thread on here, because it gets mocked. I'd like to keep this build thread on topic, so send me a PM if you want to discuss late model Toyota stuff. I simply posted a to-do list to keep my work schedule in order.
Anyways, let's keep this on topic. The wonderful Japanese Poutine.
