I started breaking down the front axle this week. Starting with the beadlock for the front driver side. It leaks pretty badly.
The nuts used are these round knurled thingy's. Suffice to say when they spin freely, you can't get a vicegrip on them ('cause they are round) and I had to grind 14 of the bolts off. PIA. Yeah, that outer ring has seen some action! Bead on the tire looks good.
I've got the driver's side front completely broken down. The only challenging part was figuring out how to get the knuckle off. After about five minutes I discovered the groove on the top of the knuckle so that it can slide over the top pin. Everything looks pretty good, other than dirty grease, a little bit of mud in the knuckle, and the occasional stone or ten.
Rockwell axles can come with one of three different types of axle shafts: Bendix, repezza, and u-joint.
I was happy to discover I have the u-joint. Splines are good, give or take a ding.
New one piece boot next to the ripped two piece zipper boot. No wonder there are stones in the knuckle
These boots are about the only thing I can afford from Ouverson, lol.
Boot guards from Great Lakes Offroad. These sit on the bottom of the knuckle, protecting the neoprene boot from rocks / sticks. Nice design, with an added plate on the bottom to protect the bolt heads from getting damaged. I thought this was a nice design feature, but now that I have the knuckle off, not one of those four bolts on the bottom were damaged, so I'm no longer sure it's really a valid 'concern'. The grease fitting protection is a bonus too I guess.
I picked up new inner and outer wheel bearings locally. They crossed Timken 3994 (inner) and Timken 392 (outer) to SKF BR3994 / BR392. Tomorrow I will hopefully have it all back together with the new bearings, boots, and boot guards installed.
